slychicken37
- Oct 15, 2009
- 0
- Ranger
- Engine Size
- 4.0
So I have a new 2007 Ford Ranger FX4 and am trying to trace down a few funky items, and thought others might have had the same at some time.
1. What standard power options come with the fx4? Mine has only the upgraded stereo and cruise control. I only ask as my vehicle was in an accident prior, and I want to see if it could have been switched out with different doors without the power options.
2. Intermittently my cruise control doesnt work or work properly. The green cruise light will flash when I twist the steering wheel and I can even get the horn to honk my pushing the coast button. The resume does not work, and most of the time I hit the coast button and the horn honks then the cruise light comes on and then I can hit "Set" and it will set the speed.
I have heard that this might be the clockspring? How hard/expensive is this to replace, or should I look other places first.
3. This is extra strange. So I am 100% sure the driver side rear door is is not factory as the VIN# is different than the main door and everything else on the truck. The rear driver speaker was not working so I took the rear panel off and notice that the speaker plug was disconnected....strange, so I reconnected it. This did not fix the speaker, but it did cause the door ajar light to stay on all the time. I thought I dislodged the door latch sensor but this was not the case. I then disconnected the speaker and it fixed the door ajar problem......
Any ideas on this?
4. This is easiest of all. My rear backup light on the driver side does not work. I am not getting power to that line....the passenger side works fine. Where exactly is the splice that pulls the left side power? Everything must be fine, but the splice connection must be bad in the rear. I have tried to trace the lines but it looks like it might be up under near the spare tire.
That is all for now!! I appreciate any help I can get
-Slychicken
Any ideas on this?
-Slychicken
