My 2000 Ranger 2WD with 5.0L Explorer motor stalled when my wife was driving home. Turns over fine, but sounds like it isn’t firing. Could smell gas, so I decided to check timing. Timing light indicated that the cam position sensor was functioning and hadn’t slipped, as well as the timing chain didn’t skip.
Put a timing light on each plug wire and found 6 out of 8 with signal. Two plug wires on the driver coil pack were not triggering the light. Swapped out the coil pack, no change. Swapped out the computer, no change. Removed all plugs and found that cylinders 5 and 6 were gas fouled. Cylinder 5 very minor and cylinder 6 really really wet. Cleaned both plugs and reinstalled. Still wouldn’t fire. Figured even if the cylinder 6 injector were stuck open, the truck would probably still run.
Checked fuel pressure with a gauge, but couldn’t get a good seal around the schraeder valve. By just turning the key, the gauge approached 50PSI and leaked out around the fitting quickly. Appears that the fuel pressure is sufficient to fire.
Removed the fuel pump relay and turned over truck for 5 seconds and it seemed to fire a bit (trying to clean the plugs and dry the cylinders). Reinstalled the relay and tried to start again, no change.
Any help is much appreciated.
