2.9 to 5.0L swap
motocross
CANADA
okay well my 2.9 trannys bin slippin and pucking so theres this about 1994 5.0L motor stock that i can get my hands on for basically a case of beer well what else will i need to buy for the swap this is what i figure so far
Headers( i already have most of the exhaust for it)
tranny(idont no what to look for i want auto)
rear end(will i have to change my 7.5 or is it good enough ? )
my trucks a 88 4x4 with susp and body lift and 31s
thanks for any help i no i will probly find the info somewhere but i just needed these specific answers and anything else i will need for the swap
88mudder
waterford michigan
read the tech library, it has everything u will need!
v-8power
31
Huntington, In.
You can use a c-4 tranny. You wont have to change your rear diff. But you might want to change your front diff if you play hard in 4WD.
projectnitemare
8
Osceola Mills, Pa
396W
If you want to keep the fuel injection you will need all the 5.0 engine electroics too. You need to see if it is a 94 for sure or not. 94-95 with the stang is when the computer controlled transmission came out, the AODE. If you stay before the computer controlled stuff here are the trans options. Manual: T18/T19, NP435, (4 speeds) M5ODR2 or the ZF (5 speeds). For autos the C4, C6 or AOD are the choices. There is nothing wrong with an auto. Anymore any of those autos will need rebuild; they are going on at least 20 years old now. You will be replacing the front axle if you beat on it at all. Plan on replacing the 7.5 with an 8.8 as well; I've broke them with a 2.9L. The body lift will help you a little bit too.
Matt
