2.9 Pandoras box
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
usually the land at the top is visibly fractured...and if the ring died a horrid death the cylinder writes the novel.
bind/hang is suspect....step 1 compression test....step 2 leak down. step 3 pull covers and crack out degree wheel if two is kicking you in the berries....
then.....lift the head....get new pushrods or whatever its telling ya...
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
If you don't write a book on engine diagnosis, in the exact same way you write on here, the world will lose something truly amazing.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i wish my ol man would write one.....especially for 351 windsors and the 300 six.
and harleys....hondas and guzzis....and....and and.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,577
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
As much as these engines suffer from top end lubrication... I would probably ensure that the rockers rotate smoothly on the rocker shaft also. There could be an issue with a rocker binding up and not letting a valve close.
This still wouldn't explain the scratching noted on the piston.
97RangerXLT
4,012
Fishers, IN
2"
31"
along with Gump's suggestion,, what about a weak spring, one that is not pulling that valve up into the seat fast and or far enough?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Just out of curiosity... Which heads are on your engine? And what year is your block?
Pix3L8
40
Connecticut
Bronco ii
2.9L
when I get home ill add a video I have of it running and pictures, I have a video of it running with the timing all whacked out the first day I got it running and a one later that day when I got it timed correctly, maybe that will help
Pix3L8
40
Connecticut
Bronco ii
2.9L
the block is an 87 with to my knowledge original heads, the block also has an AcDelco sticker on it and a bunch of specs from a previous rebuild, bored pistons, shaved crank etc etc. and I know Ac Delco is not Ford affiliated and I have no clue when they did the work, ill upload pictures later
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
The plot thickens... ;brownbag;
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
It's really never a good idea to bore the pistons...
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Good advice. Pistons like excitement. Dump gas on them and blow it up.
Pix3L8
40
Connecticut
Bronco ii
2.9L
alright, gentlemen, I'm going out to the shop to take some pictures for you
Pix3L8
40
Connecticut
Bronco ii
2.9L
alrighty, I went out and took some pictures for you guys. I took a picture of the piston, the rods, the block, and the head as well as one of my crusty plugs.....ok rangerstation...do your thing
Pix3L8
40
Connecticut
Bronco ii
2.9L
I'm starting to think purchasing a new block or salvaging one from a junkyard might not be a bad idea, and just reuse my oil pan, intake, and all the accessories I already have. I'm tired of messing with this thing and ide like to just build the motor one more time and be 100% positive it's correct, in spec, and going to get me down the road. also, note that cyl above looks very clean because I wiped it down looking for damage, all the cyl looked sooty and pretty much the same when the head came off. I put some oil in the cyl while I was at college for the week so cyl 2 and 3 look much dirtier than they actually are.
dirtman also commented about the bore, I got the truck as is and drove it 30k with no real issues I wanted to do a good teardown and rebuild over the summer and that's when I realized someone before me had done some customizing to the bore and crank (I suspect someone hooned the truck a little too hard in the past and blew the engine to hell, also note the block is sleeved with the .040 oversize.)
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
it gobbled down something.
