2.8 timing
85general
washington
2.8 V6 durasparked holley 350
what the easyest way to time the 2.8 ? iv never timed anything with timing gears so idk how to go bout it
85_Ranger4x4
17,908
SW Iowa
Ignition timing or engine (camshaft) timing?
igiveup
Edmonton Ab. Canada
Hello
I power tuned it with the computer installed but if you have durasparked it the do it like the old carb setups.
Make your life easy and convert to duraspark. The motor will run so much better. Computers and 2.8l dont mix.
just my .02 cents.
igiveup
Eric Kropp
Prunedale CA
2.8
If it is stock, there is some information in front of the radiator that has the timing info, seems like it is 14* on '85's but not sure. What ever the case, highlight it on the pully un-hook the spout wire at the distributor and check timing adjust as required. Plug the spout back in and go....
Eric
85general
washington
yea but doesnt it have to be atleast running to use a timing light? it wont get running yet. easyest way to get it to top dead center i guess then just turn rotor to #1 cylinder ?
ammocj
Yeah, what you said.
Get #1 TDC and set distriduter so rotor is pointing at or just before #1.
If it doesn't start (or even try) you may have to turn it 180 degrees.
If you have the valve cover off on #1 side, you can turn it over until the intake valve (on #1 Cylinder) is closing and line up the timing mark as it comes up to the pointer. This way you know you're at TDC on the right cycle.
Seems like I'm always off 180 degrees the 1st try.
Al
enginepaul
12
Northern California
2.8
With the spark plug removed, you can tell when you are on compression. Look at where the the rotor points, use that as number one. You now have TDC and the #1 plug terminal.
85general
washington
well got it running last nite, my problem was the new rotor was a lil bit lose fixed that an fired right up ! duraspark worked lol sweet deal
