2.8 rebuild !!!!!!!
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
1989,
18% of 20 is 3.6 (mpg). Good luck dropping in a used 4.0L and getting that 👀
Definitely contact Angie on those PARTS!!!
I only know a little about the 2.8l. There are 2 piston heights, the higher compression height is for the old Pinto engines.
• They should be worth 1 point of compression
• multi-angle valve job
• Milling the heads 0.035" will get you another point of compression .
• a complete bottom end balance will improve the overall efficientcy +10% (hp/tq).
• lose the crank shaft driven fan/clutch for an electronic fan
• custom reground cam (I would expect a solid +10hp, probably closer to 20)
• headers and free flow exhaust +10 solid (Svenn says more)
If you commit to rebuild, then pistons and rings are in. There were a ton of aftermarket headers for the old Ford v6's, so used SHOULDN'T break the bank; I remember Edlebrock had the TES (tubular exhaust system) in every old truck magazine.
A sourced, home build exhaust can be done very well for under $200, even in stainless. Fan kits are much easier to come by these days for <$100
**Summary**
Balanced bottom end (+10%), head mill (+4%), higher compression pistons(+4%), custom cam (+15hp), headers and exhaust (+15hp)...and losing that fan frees up a serious LOAD add an engine oil cooler. Your power, torque and fuel economy will see the approximate 18% efficientcy improvement plus, on paper anyway the 30+hp/tq bump.
With any rebuild, I can't help but suggest a new timing set, oil pump and water pump.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
This thread was from back in 57....
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
gaz
656
Wa, Bremerton 98310
Bobby,
My bust, I usually check the start date...DOUGHT
Can't even find decent thread jumpers these days.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Leave it....it's an awesome post and will help on search.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
No one uses that shit
BTW whats the biggest tire size i can fit on a stock 3rd gen 2wd?
4x4prepper
216
Atlanta
I had a 1997 Ranger with a 4.0L, 5 speed manual, 4x4, P235/75R15 tires, 3.27 gears, and got 21+ MPG on combined driving. Which was far better then the service manager's dog 3.0L/AT, not to mention much faster. I use to get 18-21 MPG in my 1995 Aerostar 4.0L AWD. SO, you can expect about 18-21 MPG with the 4.0L. My current 2.8L carb gets about 15 MPG, less then that when towing, BUT, I barely drive it 1,000 miles a year and some of that is warm up time.
gaz
656
Wa, Bremerton 98310
4x4prepper,
I'm not saying that a well thought out fresh build or well maintained, beloved family truck's Ford 60°v6, 4.0L ohv can't get 30mpg in a Ranger or BII, just not to expect that type of performance from the average 22+ year old junkyard pull...as is turn the key today. As the 50 year old thread suggests for the $400 or less 4.0L swap.
