cckc135r
- Sep 4, 2008
- 0
- Derby KS
- Ford
- Engine Size
- 2.8 liters of German fury
Okay, so here's the scoop folks. I just picked up an 85 4x4 Ranger XL for $250.00. It's got the 1350 t-case and manual hubs a 5 speed ps cruise pb air and is rust free. Previous owner (PO) said it wouldn't run. I got it to fire and run tonight by checking grounds and cleaning some connectors and it fired right up and ran very smooth.....forgot to mention that I also got the paperwork for a rebuilt engine that's in it as well. Motor has roughly 5 to 6000 miles on it. It was only driven to work and back 4 to 5 miles a day for the last 2 yrs. The PO also said that it had a small coolant leak so tonight I saw where it is going....out the tail pipe as steam. The oil was very dirty but no water in it. Anyway, so I'm thinking head gaskets. I've rebuild a 2.9 before and know they have heads bolts that have to replaced after each use....are 2.8's the same way? Are there any suggestions that any of you guys have before I tear into this thing? Any and all suggestions are greatly appreciated.....this Ranger is a DD so a V8 swap is not an option for me. I'm thinking a head gasket set and have the heads checked for cracks and straightness and mill if needed. Any other suggestions are welcomed. Thanks in advance.
