- Oct 5, 2007
- Reaction score
- 2,989
- Location
- Toledo Ohio
- Make / Model
- Fords
- Engine Size
- 3.0 2.3
attempt #2
above is an intake port, note the 2 valves
above is thermostat cavity
below is coolant pump cavity, note it is part of the block.
below is oil separator, there is a hole behind it that exposes the crankcase. blue elbow is PCV valve, another bolt is hidden behind the hose.
lower right is oil filter adapter location.
upper right is Exhaust Gas Regurgistation tube
[ATTACH22710][/ATTACH]
well the additional attachments didn't work as planned
