2.3 stick shift
Rangerdangerrr
California
In the morning, the truck cranks and cranks takes a little bit to turn over and fire up, has a weird idle, little bit of hesitation while at stops in the morning on the way to work. Once warmed up seems to smooth out also hesitation while just driving in general, just bothers me. I have replaced the plugs, wires. I have been reading. Could it possibly be the throttle position sensor? Not sure. Maybe even the iac vavle. Or even the egr valve. Just wondering if anyone else could shoot me some advice, thanks!
tomw
46
lima bean
vertical and above ground
Could also be the air or coolant temperature sensors. Both are used by the computer to determine how much to enrich the fuel mix when cold, and also bump the cold idle until the engine warms enough for a good stable idle.
You can check their output using a VOM and a table of resistance/temperature.
If you get a fast idle when cold, the IAC would likely be working. If you have an automatic and the idle is stable going from Park or neutral to a drive gear, it is likely functioning.
tom
