- Jul 10, 2009
- 1
- hartville ohio
- ranger XLT
- Engine Size
- 2.3
Hi, need a little input on noise when working clutch. It sounds as though clutch cable is rubbing when you use it. Only when you are actually pushing in or releasing it. I'm pretty sure not a throw out bearing or pressure plate issue as it's only when the pedal is traveling. No noise anywhere when you stop the pedal anywhere in it's travel. So, real question is: are there any lube points on that linkage/cable? After screwing around with this setup, I long for the days of solid linkage. Lee
