1998 Ranger 2.5L Exhaust manifold torque: FSM says 45-59, TRS says 14-21 ???
rnsc
NY
Ranger2.5L2WD
The big green Ford 1998 Ranger Workshop Manual says 45-59 ft-lbs on page 303-01A-47 (Stage 1 15-16, Stage 2 45-59),
The Ranger Station Specifications page says 14-21!
Can anyone speak to this? I would normally consider both to be authoritative, yet that is quite a difference!
I *assume* that alot of people have used the 14-21: Any problems?
Has anyone done the 45-59 (52 nominal)? Any problems?
Any words of wisdom as to which would be a better gamble?
Thank you!
--Ray
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
59ft pounds seems awfully damn tight for exhaust manifold bolts... they are only what 5/16" studs? Going off a basic torque table for that size bolt/stud 20ft pounds is more appropriate.
rnsc
NY
Ranger2.5L2WD
I'm new to car work. Just trying to follow directions! They are M10-1.5 (0.025 larger than 3/8").
Generic advise points me in the right direction. Good idea looking up generic torque values for M10-1.5 bolts. They agree roughly with your numbers (They are higher, but labeled as the maximum torque).
I loosened them and re-torqued them somewhat arbitrarily to 216 in-lbs (18 ft-lbs). Originally I torques them to 450 in-lbs (Three quarters of what ford said) or 37.5 ft-lbs because I slathered them with anti-seize. Boy, that felt like a lot less than the half. Must be OK!
Thanks for the help. About to put another one in for spark plugs, should be in about 8:15 EST.
--Ray
