1998 3.0 high idle when clutch is pushed in UPDATE
dmb2613
23
23962
ranger
It is worse when it is cold , engine reves to 3000 at stop sign [ manual trans] it will come back down but takes a minute or two. I installed a new IAC valve same thing.
Thoughts please
Thanks David
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Vacuum leak...
superj
2,577
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
smoke test time
dmb2613
23
23962
ranger
cant find any vacuum leaks, it will come back down to an idle , about 700 rpms when I stop, idles fine until I drive it, does not go to very fast idle [3000 rpms] all the time.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
you sure the throttle cable isn't sticky or hanging open?
dmb2613
23
23962
ranger
today I unplugged the IAC valve and no more fast idle, works fine so there is a problem with the signal coming to the IAC vale , thoughts please
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If the truck idles more then about 500 rpm... you have a vacuum leak or maybe someone has adjusted the throttle stop screw?
When the IAC is unplugged... the engine should nearly stall or stall. It would most likely stall if you put it in gear.
Can you read TPS data? At closed throttle TPS voltage should be less then 1 volt.
dmb2613
23
23962
ranger
idles around 500 rpm
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Still idling around 500?
dmb2613
23
23962
ranger
Yes, but I hooked it back up this morning
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
smoke test time
dmb2613
23
23962
ranger
I got a Motorcraft one today and all is well. the aftermarket ones dont work for me
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
New just means not tested to me. There is a way to set the idle stop screw, tech section.
