1993 Ranger XLT 9" brakes seized
4.6StangRage
My Rear Driver side Brake is locked the shoes are firm against the drum. How would I go about un-seizing these brakes?
MAKG
19
California central coast
Open the bleed screw if the problem is hydraulic. Release the parking brake and whang the drum with a hammer if that's the issue. Failing that, back off the adjuster (PITA).
If you can rotate the drum by hand, pound it off with the hammer.
4.6StangRage
thanks ill check it out today!
TireIron
Methuen, MA
also take a look to see if the brake cable is locked up, if so then you need to get that sucker to free up and the shoes will let go.
4.6StangRage
thanks for the help... I have found success! It was a hydrallic issue. I just bled them but the fluid needs to be completely changed its pretty dark.
