1993 ford ranger wont start
awsskater4life76
garden city, MI
2.3l 4 cylinder
i have a 1993 ford ranger 2wd 4 cylinder 5 speed 155,000 miles. and my truck wont start i have a 12volt + new batter, new starter, new starter slynoid. and i turn my keys everything powers on but i dont hear anything no click and the starter doesnt kick on but when i put a screw driver on the syloid it starts right up ive replaced the syloind twice and it holds a current cuz i tested it with a volt meter i cant think of anything else do try and ideas guy thanks, jeff
Irokranger93
Michigan
Corosion terminal::: check if the starter wire pole of a battery is in good shape
misterW
4
this happened to me several days ago after switching engines. key turns lights and stuff on, but won't activate starter. truck started with screwdriver technique. i ended up putting a manual push button starter in, just linking up the positive pole on the solenoid to the tab on the solenoid with a push button in the dash panel.
JEB1962
Did you check the nuetral safety switch?
modelageek
14
Boston, MA
+1 with the NSS. I call it a clutch positioning switch on a manual tranny.
YOur "starter control circuit" is not working. A component of this is the clutch positioning switch. if you have a haynes manual there is a wiring diagram toward the back it will show you exactly how it works. also check the starter relay that is easy to check.....
Irokranger93
Michigan
same thing for me!!!push button in the dash panel ---»two wire from the dash to selenoid relay
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
i hate seeing things like this when i get into a car lol.
anyways OP, have you tried checking any fuses? and the clutch safety switch is a valid place to check also.
does your starter solenoid have a good ground?
Irokranger93
Michigan
look here
(Clutch Pedal Ignition Lock Switch)
97ranger xlt
11
Mass.
also check the small wire going to the solenoid. if that is not good and tight without corrosion then the starter won't turn on with the key switch.
metricman
Ing switch mounted on the steering column, that fixed mine. they have a tendancy to come loose at the pinch tabs, you can try to wiggle it and get the truck to crank.
