1990 4.0 battery terminals
Deamers87ford
Lancaster, Pa
how many power wires go to the + on the battery i only have one and i think there should be another but idk where it comes from
skynast
Only one on my 96. Any extra would be for aftermarket parts not running through the breaker panel such as car alarm, spot lights, winch, etc.
Deamers87ford
Lancaster, Pa
dang i cant get power in my truck at all
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
So you have no power at all? Did you make sure your ground is on and tight? In a stock setup you should have only the one power cable from your + and your - will have two the main that's grounded to the engine block and a smaller one leading to your body.
Deamers87ford
Lancaster, Pa
ill doubt check my grounds this was a 2.9 to a 4.0 swap if that changes anything
xkotyx
20
Waynesboro, VA
on my 91 explorer i believe its 2 wires that are on that actual positive terminal. not sure where the small one goes, never paid much attention to it
Deamers87ford
Lancaster, Pa
man you do great work i just wish i could get my ranger running
Deamers87ford
Lancaster, Pa
could you explain where all the wire go to then off battery?
Viper Command
6
Crestline CA.
2x'97-'88-'98-'
Ranger,Ranger,
3.0,4.0OHV 2.9, 4.6DOHC, 4.0SOHC
Off the +pos, there should be two, 1 to the starter, and 1 to the fuse box.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
one positive goes to the starter lug, the other goes onto the fender mounted solenoid. the positive cable for the fuse box gets its power from the cable attached to the solenoid.
multiranger
Praise the Lowerd!
MTOTM Winner
17
Loganville GA
Isn't there one off the alt to the + side of the battery??
