1988 Bronco II/Ranger Brake Line Size
Darksyne
Perryville, MD
I had a hard line break on the Bronco II the other day. Does anyone know what size the factory hard line is?
Thanks!
Darksyne
Perryville, MD
Awesome, thanks for the line size. The nut size doesn't really matter since I'm splicing in a new section.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
krugford
Iowa
When a brake line rusts out like that, it's probably better to replace the entire line. It'll save the hassle of having to fix the line again if another area rusts through, and it'll be safer too.
projectnitemare
8
Osceola Mills, Pa
396W
There is nothing wrong with splicing in with a flared end and a union. No different than the fittings at the wheel cylinders or at the rubber lines. Replacing the entire line isn't much more difficult or more expensive than splicing into an existing line. Either way just make sure you do a good flare job. Use a tubing cutter, file the burrs from the ends and a double flare will perform better than a single flare. Take your time and do it the right way.
Matt
krugford
Iowa
I wasn't thinking that a spliced line would be unsafe because of the splice. The stuff I usually see here is rust related, and where there's one rust hole, there's bound to be more. Like he said, if you take you're time, either one will work fine.
-krug
