1988 2.3 distributor to 2.3 durasprk
wbermont
1988 2.3 distributor to 2.3 distributorless
Hello everybody. I'm looking for advices on how to repair or swap an engine 2.3 with distributor on a 1988 ford ranger. It looks like the piston wrist came off and cracked the piston wall. I've been looking around at the junk yards and I can't find the same engine but most of them have 2.3 distributorless 8 spark plugs. I'm wondering if some of you guys have done this swap before. I would like the same 2.3 engine due to GPM and my low budget, but I don't know if this engine will fit or what will I need in order to make this work. I would appreciate any advice on how to fix my ranger.
bmax77
I am finding the same thing. I too have an 88 2.3 4 plug engine and was thinking the same thing. Did you do it and get it to work and if so what all did you have to change? I need help as well on this.
John Smith
6
In my case...
I have been collecting older 2.3L engines as i I find them,....many times they can be had for very cheap ...at least in my area....since this block goes way back to the 70's....if you like duraspark....the tfi can be replaced with the duraspark setup very easily....
I'm not sure when they quite drilling the dist holes in the block...the latest one i have is an 88....and it came with the roller cam.....a plus in the newer motors i guess...
the weakness seems to be the heads...if they have been raced hard...the blocks/ cranks/ rods seem to be bulletproof 4 the most part....
I have (2) 78 motors with the original pistons
these early engine are very popular for the circle track guys so they may be harder to find..but it can be done....and cheaply too if you make a quest out of it i bet....
good luck
6.9l ford
To swap in a duraspark dist. from a tfi dist, you can use a repair manual for a mustang, ranger, LTD II, pinto,& all 2.3l powered cars from 1976-1985. I cut one from a pinto & wired it into my brothers 1986 ranger years ago, it ran great with no more tfi problem again. :icon_thumby: If you need more help just ask.
vince87ranger
woodland, IN
as far as i know up to 92 has a distributor hole, i used a 92 mustang 8plug shortblock with a 4 plug 86(mabe?) head. took all the injecton stuff off and ran a carb with a duraspark. the stock mustang had a magnegtic pickup behind the timing cover,took the thing off and ran it. far as looking for a useable block, look where the distributor shuld be, if it has a distrobutor clamp holding a button looking thing in you can take that out and put in a duraspark or whatever dizzy.
