1987 ranger lowering beams and brake upgrade
OkayKafka
Seattle
2.3L Turbo
First off. Forgive me if this has been covered. I did search.
I've been looking at fixing the front suspension and making it level. Im looking at getting the DJM dream beams and getting new springs and shocks.
My main question comes from what kind of compatibility they have with upgraded dual piston brake calipers. I'd like to upgrade the brakes to dual pistons from a newer ranger. I know that on my 87 I will need to get I-beams along with spindles/ knuckles. My question is if the beams are able to stand in as that upgrade or if I need different beams. I'd like to be able to have the lowering beams in there done can upgrade the brakes: but at the cost I only want to do it once.
JoshT
1,780
Macon/Fort Valley, GA
It has been well covered, you need to practice your searching some more. Will give you credit for attempting to post in the correct sub-forum, rather than just throwing it up in general discussions.
Let's make sure I'm reading your post correctly. Your front suspension is in rough shape and you are wanting to make some changes while you are fixing it. You say "making it level", but I assume you mean lower since you are asking about dream beams. While lowering it you want to upgrade the front brakes to dual piston calipers. Would this be correct?
Your last two sentences are throwing me off.
The DJM dream beams are a direct replacement for the stock beams, they just make the truck sit about 3" lower in the front.
As you seem to know, in order to use the dual piston calipers you will need to use the 89-97 I-beams and 95-97 steering knuckles. DJM makes two styles of Dream Beams for the Ranger, one for 83-88 models and the other for 89-97 models. Buy DJM Dream Beams for the 89-97. You can use them with the 95-97 knuckles and calipers to get the dual piston upgrade.
It sounds like you want to fix your front suspension and while you are in there you want to lower the truck, but you want to put the brake upgrade off for a later date? You want to make sure that the beams you buy now can be used with the upgrade then?
If that's the case get the 89-97 beams, a set of 89-94 knuckles, and use your stock calipers. Then when you get around to doing the brake upgrade all you'll need to do is install the 94-97 knuckles, calipers, and brackets.
OkayKafka
Seattle
2.3L Turbo
Yeah, I found what I was looking for eventually. I just had to read a bit more. Thank you for your patience as I newb it up here.
Yes, the front is messed up from when someone cut the springs in the front and lowered the rear. It looks goofy and bounces badly.
I would like to hold off on the brake upgrade. I'm debating if it's even worth it I may put a different motor (2.3L turbo) in there which is my motivation for dual caliper. That wont be for a while though.
I assume I can't use the stock 87 spindles and calipers with the 89 beams? Basically I have a fair amount that needs doing on the truck and would like to just buy as little as possible while I make up my mind or work on other parts that are needed. I do like that the knuckles are only $75 per side via ebay $60 for the 95.
I think I may just go for the upgrade. May as well do it even though I literally just got remaned calipers for stock that haven't been hooked up yet. I may just put those on ebay and sell them for what I can.
JoshT
1,780
I would like to hold off on the brake upgrade... would like to just buy as little as possible while I make up my mind or work on other parts that are needed
You can do that and still get the later model Dream Beams. You will not be able to use the 87 knuckle with the 89+ beams, but you can use 89-94 knuckles instead. Those later knuckles will work with your new remaned calipers and existing brake components. That would save you from having to get calipers, pads and rotors right now.
Then when you get ready to upgrade it's just a matter of swapping to 95-97 knuckles, calipers, rotors, and pads. You'd already have the later model beams installed, won't have to buy them twice.
It's all up to you, I'm just throwing out some options.
Check on car-part.com for used steering knuckles in your area. I did a quick search for Washington state and saw the 89-94 style knuckles as low as $35 per side. Didn't check, but the 95-97 is probably close to the same.
Gregin30655
14
Monroe GA
Ranger GT
When you use the later model beams and knuckles, how much does it change the track width? Is in .75"?
I am ordering wheels and tires when I order the drop kit (a djm kit for 89+ for an 88 and 95 knuckles and brakes) and I need to be sure I calculate offset correctly.
JoshT
1,780
It shouldn't, but I've never actually measured it. My truck is also in pieces, so I can't exactly go out and check it for you.
You'd really be better off starting a new thread to ask questions like this, instead of posting in one that's over 4 years old.
