1986 Bronco II 4x4 spindle question
mark5bronco
Athens, AL
ford/bronco ii
Hello--i thought I posted this already but couldnt find it. i am replacing my ball joints and i removed the spindle from the knuckle. Problem some of the rectangle bearings fell out. it looks like the bearing is compressed inside the spindle. My problem is how do I replace the bearing. thanks in advance for your help.
SenorNoob
584
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Rectangle bearings? How's that work?
I think a picture or two is in order here.
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
If I remember right, there’s a needle bearing in there. If parts are falling out, it’s probably shot. You’ll need a new bearing and seal and they can be a pain to get out. Been awhile since I looked that stuff up and it can be a little tricky to source if I remember right. It’s just a tiny little bearing that goes in there
mark5bronco
Athens, AL
ford/bronco ii
thanks i finally got it out-it was a little difficult--i had to use a slide hammer that was attached to two claw like things. the needle bearing was shot and i was able to install a new one--thanks again for ur comment
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
Think you got luckier than me, I want to say now that I think about it, I’ve had to remove all of mine splitting them with a cold chisel, a lot of cussing, and a lot of care. If you can use the words cold chisel and care together anyway, lol
