- May 18, 2008
- 368
- Vancouver area BC Canada
- 92 & 83 project
- Ford
- Engine Type
- V8
- Engine Size
- 4.0L 302
Starting a new thread here with the newest ranger to enter our fleet of vehicles.
From this thread carry forward.....
UPDATING: ......
(Missing key for the tumbler, was going to replace it with a tumbler i have on the shelf, while i was at work angie started shoving old keys into the ignition, BINGO! found 1 that worked, then when i got home i tried 2 more different ones... yep we have 3 different keys that work in the same tumbler)
2 days ago we were able to get a battery into it, add water, oil, and put some gas into the carb, after a few revolutions, the little 2.8 fired sputtered and came to life..... very noisily, but it did have life. ..... water was leaking out of the side of the block as it was being filled in the rad. Didn't pay much attention just kept adding as it was lowered. water was flowing freely from the water pump so i knew we had good circulation. we let it run for a few minutes then that was enough for the day. she ran and was starting on first crank, was impressed and happy with that.
Yesterday placed the truck on a set of ramps to get under the front end better and take a more in depth look at the rig. First plan was to take off the passenger side exhaust manifold for a better inspection of where the water would be leaking from... then easier way was to just remove the oil filter and look from that advantage point. laying under the truck with angie pouring water into the rad... BINGO water was leaking from a frost plug... well doesn't that change everything..... returned the oil filter, then fired the truck back up..... sure enough, frost plug is not sealing ..... ok interesting for sure....
Started to examine for the crappy firing ... basically sounded like a bad sporadic vacuum leak somewhere .... my very first impression was a blown brake booster .... but did the usual inspect for missing caps, check the lines, and such .... all visually seemed fine ..... fired her up let it run as all hoses were juggled and played with to see if there were any changes in revs .... nope nothing. got angie to kill the ignition .... then i heard it.... YEP air leaking in the booster ... BINGO .......
2.8's have adjustable valve trains so that will make it run quieter when i get around to redoing the lash on this engine. maybe the heads and gaskets are all ok on it, just needs a good tune up, fixing the vacuum leaks, addressing 40 year old abuse might just be all that it needs....
in the cab of the truck is a box of new parts, complete top end gasket set, all water hoses, water pump, jugs of coolant, oils and belts. bonus stuff for sure.
i know there were questions asked from the other thread, i didn't forget you guys, just haven't had a chance to get the answers yet. and i was asked about the ford authorization sticker, i haven't checked that nor had my camera with me to take a pic. will do that soon.
cheers and stoked on this little truck
seriously thinking 1984 camper
this is calling my name. can anyone give more info about this style camper? i have a couple 2.8's sitting on the floor ready to drop into this truck. cheers https://vancouver.craigslist.org/van/cto/d/vancouver-rare-vintage-ranger/7540185656.html 1984 ford ranger roll-a-long pop top...
www.therangerstation.com
UPDATING: ......
