10 tooth starter drive gear mod - Starter getting stuck in flywheel
MadMax_636
47
Georgia
2.8 V6
2.8L
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
So, Recently after doing my duraspark mod and the 10 tooth starter. It ran and worked perfectly.
Today, I went to start my truck and I stalled it out because she was too cold to start driving (Still working on the choke/high idle system) and when I went to start it up I could hear the starter grind and I got under the truck and the teeth were fine. I noticed the starter was still engaged with the flywheel. I then unplugged the coil and cranked it and when I stopped cranking it would make a clunk sound. The starter was still stuck. I am mainly asking if yall have had this issue and how to fix it. I had this happen before but it was because the starter was misaligned and with the 9 tooth. I will be taking the starter off and re-seating the drive and putting it back.
