'04 Ranger front brakes
Olsin6
Okay, so I ordered a Power Stop brake kit from Summit Racing. Double check the application to make sure everything would fit my truck. It said everything was good.
I pull apart my truck, stick all the new stuff on and go to install the caliper bracket. Doesn't fit.:icon_confused: I then look at the rotors. Wow. My current one is 10 1/4 inches. My new ones are about 11 1/4. Is there another set of caliper brackets that I can purchase to run the bigger rotors? Or do I have to spend $60 to ship this things back?
Thanks
2004 Ford Ranger XLT 2wd.
Tee Rev
Calgary Ab Canada
The cheapest route is to return the rotors.
Ford changed the knuckle for the larger rotors.
You could probably find a pair at the auto wrecker, but you'll spend more than $60.
Olsin6
Wasn't the larger rotor change in 2001? Why would my truck no already have this? These are also mounted onto a lift spindle if that changes anything.
Tee Rev
Calgary Ab Canada
Both rotor sizes were available depending on the model, up to at least 2005.
