- Aug 10, 2007
- HIGHLAND, MICHIGAN
2" coil spacers with moog HD cariable rate springs, belltech shackles in back, 30x9.50x15 bfg ats on cragar soft 8s.
2003 ranger fx4
no body lift
no suspension lift
torsion bars cranked 1 inch in front
265/75/r16 bfg ats
16x8 inch wheel (+12mm offset)
no rubbing, no trimming
1999 ranger xlt 4x4
torsion crank up front with stock lift block in the rear
265x75-r16 michelin ltx at's
SAS EB D44 with 7" EB lift coils, stock RBV coil buckets
5.5" Chevy rear leaves w/ stock Ranger 2.5" block and 2" shackles
35x12.50-15 Goodyear Kevlars on 15x10 rims with 4" BS
Another D44 SAS Ranger from Wooster Ohio
3.5" Early Bronco Springs and a 1" body lift. Stock 2.5" rear block with GM lowering shackles. 36x14.50 TSLs on 15x10s
I cant believe I have never seen you around before. Im not driving the truck up here anymore though.![]()
Hey guys, i finally got the new flares on. What do you guys think? Keep??-Rip Off??
This is the most current "side" shot I have. I will add more soon.
1994 Extend Cab 2.3 2wd, 6 inch Skyjacker lift, dual steering stabilizer, 3 inch body lift, Front-33x1050x15 BFG A/T Rear-33x1250x15 BFG A/T
