I know what you mean. When my buddy took out the plasma and just HACKED it way down, i was like
Well we're both right. It looks like I hacked off enough to clear things as it sits now..... But then I realized "Hey Dummy, where you going to put that hydro ram when you get to that point?". So after a :homer: moment, I'm going to need to cut the tar out of that thing to make room for the ram. Unless I decide to the ram lower on the axle. Time will tell.
Detail work allways seems to take forever, so there hasn't been many things to share as there isn't much to see. I do have an "offical" update post that I'll get up here in a bit as well as some updates to do to the other prior posts.
The truck is ready to trun around at this point, as soon as poly gets me the arm I need to get the steering giong. If it doesn't show up soon, I'll just rig something up to make the turn.
The "Done" list
-44 is under the truck and located correctly
-Shackles are done (I'll post those in a bit)
-Had some rust repair to do on the rad core support (not bad enough to replace the support, but annoying) also had to fix one of the front body mounts.
-The cab is now 2/3's bolted on right now, and is currently lined up correctly (that took way to long to make it right).
- Front corss member is done
- Started on my winch mount
Front Punch List
- Brakes
- Shocks
- Some sort of steering
- Front DS (after doublers go together).
- Need to order the correct lug nuts for the H2's
We're getting there! Heck, I even started the thing for the first time since 2/15/11 today. Has the same stutter it had when I parked it (dang IAC
here's something to look at:
Body Mount fix:
Core support Rust Repair:
I jacked up the Rear of the truck to get some measurements off of it:
Frame rails should be 22 - 1/4"
Front Frame rail looks to be 27 -1/4" (1/4 too high)
Rear Frame Rails 30" (1" too high)
So I'm really close, and not doing too bad seeing as how I started on 2/15 with this, and I'm working alone.
