rngr4x4beast
its a 02 ext cab ranger where is the door ajar switch located my door ajar light stays on no matter how hard u shut the door and i cant find the switch is it built into the latch
It's inside the door, attached to the mechanism of the latch. WD40 is a temp fix.
well havent tried the wd40 thing yet but if that doesnt work could i wire the 2 wires together and keep the door ajar light off for good i no it will mess with the dome light when you open the door but ill just use the switch on the dash for that
as i stated above IF the wd40 trick DOESNT work could i wire the wires together because i aint payin 20 bucks a piece for a little switch thats in the door
