got it running, made my metering block, and im having a few problems. i have my metering block set up about right. it feels kinda low on power though on the mid-upper rpms. also i had to cut my wires comming from the tranny, and i have the only ones in the 4 wire plug except the blue wire(have the red/lt blue, and the one for the reverse lights and all, but my t/c lockup isnt working. i had the lockup switch before the duraspark. the only wires comming from the trans that isnt wired up are the yellow ones and one red one
btw after i wired up everything correctly the 2 yellows and one red isnt wired up. where do they go? and why isnt my t/c toggle working?
also it has an erratic idle and stalls when i stop quick. i have all the vacuum lines that arent used capped off, inluding the one going from the back of the carb to the choke heater thingy. how do i adjust with the 2 screws on the bottom of the carb at the front?
