FAST Fabrication 94 b4000 turn into SNORE class 7 race truck build thread
Installed are battery
Started on sway bar completing today
Got the Sway bar all mounted up and built a sweet dimple gusset plate, just need to fully weld it...
started on fuel cell relocation, built a gusset plate for back of frame will have a dimple in it and have front mount to fuel cell welded to it
also FAST Fabrication has got their Facebook page and business page up and working on myspace and twitter page then the website. We are doing a $250 basic bumper special just like the one on the 2001 A-Arm ranger. Also working on getting finished models of our jack skids and light bars all at unbeatable prices.
got lower link arm for sway bar pocket done and level out housing for bump pad
bump cans fully welded
rear gusset which also was used to mount fuel cell due to relocation
fuel cell back in
sway bar mount
you can now follow FAST Fabrication and the other division of FAST Industries as well as our builds and product releases at myspace.com/FASTfabrication and facebook.com/FASTfabrication and twitter.com/FASTFabrication, add us and join the FAST team
how far off driveshaft needed to be extended at ride height... getting custom one made
full droop, roughly 35" of useable wheel travel, going to strap at around 25
bump, where can will will hit on axle
fuel cell clears now
spare mount is done, finishing fabricating the spinners
sway bar completed, going to add a quick disconnect pin set up
cpl dooped pics of A-arm ranger, working on front bumper for a explorer and frontier this week for customers
thanks to our sponsors PRP Seats at prpseats.com
looks like a Threat front end, awsome build, this should be posted in the prerunner section
Welded and completed sway bar, bump stops & pads
spinner parts welded, still need to weld handle bar, studs, and lil gussets
Axle painted, extended stock driveshaft in, suspension fully bumped plenty of clearance
from back half
from fuel cell
from battery box/differential
and from wishonbe and backhalf
Vision X lights...one 9" and one 7" to mock up light bar and bumper, work light is insanely bright comes with car charger and wall charger, poly-cabronate lenses
found tall jackstands for $60 each after ship
old shock mount pockets before cut
passenger side after cut
think i will call my truck the grasshopper or locust lol
bypass will actually be an 1" taller and coil-over 1" taller from before, causing us to need 90 degree resi fitting.
Very nice build. Subscribed.
I bet you can't wait to get it out.
Good luck,
Richard
Spinner and spare tire is done, just waiting on shock ends to finish shock mounts, then rear is done until fuel cell decision is made...
think were going to do a front mounted light bar... with 5 6.7 vision x lights
changed to blue.... only having suspension parts grey
still pushing on just waiting for parts from sway away and tech guy from MDR/MORE/LORE/etc to come check cab cage and fuel cell and rest of truck he said for sure mon or tues, so once that is done we can actually continue full on with truck figure out our options with fuel cell and go from there. School starts again 21 next month so got to get as much as I can done.
The build looks great! Like Clay said, can't wait to see her getting air-time!
