stand alone wiring harness for the 4.0
zuki
Washington Iowa
is there any company that makes a stand alone wiring harness for a 4.0?
background:
i have swapped a 4.0 into my samurai, and have run this combo for many years. it is awesome. but last run i hit a huge bump going kinda fast, and the thing quit. keeps shorting out the ignition fuse in the power block. i cannot find a short. not sure what the problem is. i have pulled the whole wiring harness out of the vehical and still cannot find any wires that are shorting out. this just sucks.
anyway i thought about find another junkyard wiring harness/computer/etc, but if there is an aftermarket stand alone wiring harness i would like to consider that. it would be nice to only have the wires in the engine compartment that were needed to run the motor, and not all that other crap. i have cut out as much as i could that i felt was unnecesarry, but to tell you the truth, i really don't understand fuel injection, so i am sure there is a bunch of stuff i really don't need yet in there. the samurai has a very small engine compartment, so all those extra wires are really inritating. when it comes to working on it, i do miss the simplicity of the carbed 2.8 i use to run. i don't miss the lack of power or the lack of relibitily of the 2.8 though.
anyway any thoughts would be appreated.
Dude.....I'd make you a wiring harness. I've had 2 93-94 4.0 harnesses apart and these are dirt simple.....compared to others anyway.
I'm actually in the process of converting my 94' 3.0 from TFI distributor ignition to EDIS6 from the same year 4.0. Easy peasy.
Seriously though......PM me with how you have your engine compartment set up, engine trans combo, year of engine, etc. and maybe we can work something out.
thanks alot, but i got it figured out.
So what was it?
Richard
not sure, i pulled the entire wiring harness and went thru it. i had a couple of connections that were questionable, nothing really that looked to be the issue though. anyway, i fixed up the questionable connections, and put it back in, and no issues since.
Are you still willing to do stand alone wiring harness for 93 ranger 4.0
background:
who make the 4ltr stand alone wires pete 3133086734
I'd buy a new ranger harness
I need help I will take photos when I go home at lunch of all the connections but I'm trying to put a 2000 Ford Ranger 4.0 in a 86 Ranger that had a 2.9 and I am lost on where to make my connections I'd rather not use the power distribution box because I won't need anything but the distributorless ignition and coils an computer and that sort of stuff. everything else all the other stuff in that fuse boxe Is not going to be carried over
Yeah I would too! Well depending on the price, you might not be as poor as I am. But I have looked. where do I find one?
you're going to need a 91 to 94 explorer or 90 to 92 ranger engine wiring harness, you're also going to need the computer, sensors, and injectors from the same vehicle. the 2000 ranger has the computer in the wrong place, uses a returnless fuel system and has a bunch of other emissions related stuff that you just don't need. Using the older stuff will greatly reduce the amount of work you're going to need to do to get it running right.
so I use the two thousand model engine replace the injectors with those out of a 92 and use the 92 wiring harness and computer? is that all I need to make it plug and play? my 2000 doner might be slightly different its an early 2000s.
it does have a regulator & return on the fuel system but none of the fuel system stuff will be carried over already have a fully functional electronic fuel injection set up in place. & definitely leaving all the emissions junk behind as well. not planning on going to California any time ever lol. so would the air inlet tubing and filter box from a 92 line up with that motor correctly? so I wouldn't have to swap my battery to the other side? are those the only differences?
Do you still make harnesses for the 4.0
