2.9 engine miss?
so check for continuity between pin 23 and the sensor connector?
yea my meter would not go high enuf the schematic shows it as a resistor probably up in the 100,000 ohm range
yea i grounded it and checked at the sensor connector disconnect the bat first
I went through and tested every wire guess i`m a little anal that way but i did find a short check for continuity then for a short
it really dont matter ur just using the truck ground to complete the circuit
did you get authorized for a membership
LOL. I got the "are you wanting more money for the truck?" look. So I will just snake ten bucks and send it in by snail mail. She's not really giving me grief. It's a-ok.
what your doing is creating a short in the wire on one end and testing for a short on the other
Upcoming TRS Events
