- Aug 19, 2001
- So. Calif (SFV)
- 2.9L
- Tire Size
- 35x12.50R15
I absolutely love it! Pretty much all my free time has been spent with this thing. Can't put it down!
LOL I only got it that muddy the one time. It's not something I want to make a habit of. There's an outdoor track near me, and the day I went, the dirt track was pretty wet. But taking things apart to clean it is almost as fun as driving it!
Funny you mention the lights. That's exactly what my first mod is going to be - if I can find them. I'm going to call my local hobby shop tomorrow to see if they have 'em. Looking around online, the few places that carry them are out of stock, although I did find them on Ebay.
Next will be another body that I'm going to custom paint.
Good eye noticing the missing steering servo! Being new to the current state of R/C vehicles, I assumed the Traxxas claim that everything was ready to go right out of the box. The fact that the steering servos would whine at rest and I had to set the steering trim way left of center should have made me realize that I needed to adjust the steering linkage, but I didn't. Within a few days of getting the truck, the driver-side servo was toast. Not totally my fault, but I could have corrected the steering and probably saved the servos premature death. I went and bought another servo, but I'm still going to call Traxxas and see if they'll send me another.
I broke a half-shaft, but that was because of stupidity and totally my fault. The range on these things is incredible - up to a quarter mile. The truck was pretty far away, and I dumped it on it's side while doing donuts in the dirt. Instead of walking out to it and putting her back on all fours, I decided to try hit the juice while turning back and forth to get her back on her feet. I failed. As I gave up and approached the truck, I saw the driver side front wheel spinning freely with no throttle. This truck is full time 4wd, and that is not supposed to happen, so I knew something was broke. Took it home to discover that the pin that goes through the half shaft at the outer end had ripped right through the plastic shaft. Fortunately for me, a set of 2 was only $8 at the hobby shop. Live and learn.
Other than that, this thing has been bulletproof. If I lose another steering servo, I will look into beefier replacements. Also, the guy at the hobby shop said I could run a single steering servo, with more in.-oz. of torque than the 2 Traxxas servos combined. Is this true?
I've heard of the single-servo mod, yes. I've also heard it requires you to get a new radio with adjustable end points for it, but I don't know if that's true or not.
I switched mine out to dual Hi-Tec 5645MG digital servos and am happy with their performance.
Yes, they may call it "RTR", but you still have to check it over apparently (I had a buddy who's servo burned out because the linkage wasn't adjusted properly from the factory). Traxxas is pretty good about replacement parts though, I'm sure they'll send you another one without any hassle (they did for me when I blew up the spiders in the rear diff).
I tried that with the axle on mine once, the metal part just doesn't fit in the end quite the same afterward. $8 gives you 4 times you can break it, I just replace them (so far I've only ever broken two plastic ends on mine, which I've had it for 8 months now). If the slipper clutch at the motor is adjusted correctly, it should be rare to encounter a broken shaft (that is, without having the lockers engaged. With the lockers you still could break them if you aren't careful. Both mine broke with the locker on).
My step pin tires are a lot grabbier than them on most any surface.
