Just Plain Stupied
I finally modified the OEM Ranger xmsn crossmember to fit the R700 chevy xmsn.....I already shortened it to 30"....I turned it up-side down & slid it into place under the rubber R700 xmsn mount...I lowered the xmsn until there was clearance between the top of it and the floor of the truk.
I needed another 1/4" of clearance...so I notched out the 2 ribs of the OEM crossmember 1/2" deep by 4" wide....then I welded a 1/4" thick piece of flatbar into the notched area to beef up the crossmember and also get the 1/4" clearance needed so the xmsn would sit correctly.
I drilled a new hole in the steel plate of the modified crossmember so the bottom stud of the rubber mount could be bolted in place.
While I was there I installed the other cat on the drivers side exhaust.
Tomorrow I have to drill & bolt both ends of the modified xmember to the frame rails.....annnnnnnd shorten the drive shaft bout 5"......practice practice practice.....
Just Plain  Stupied
Just Plain  Stupied
JULY 2022...I LOST THE PIC OF THE TRANS. MOUNT FLIPPED UPSIDE DOWN AND BOLTED INTO PLACE AFTER I LOWERED THE SBC.
Friiiii-day......
Back to the go-rajj this afternoon to finish bolting the crossmember & Re-(LOL)-shorten the driveshaft.....
  • Just Plain  Stupied
Ya know...I think once you finally finish building this thing, even after you finally sort out your cupholder dilema...you're going to secretly hope something breaks so you have an excuse to start wrenching on it again.
Just a hunch.
Just a hunch.
just a weeeeeeee hunch:icon_twisted:
Ya know...I think once you finally finish building this thing, even after you finally sort out your cupholder dilema...you're going to secretly hope something breaks so you have an excuse to start wrenching on it again.........Just a hunch.
But until then......I just re-redid the driveshaft.....I used a dial indicator....and managed to get it straighter than the OEM shaft....Waaaaa!
Just Plain  Stupied
The OEM yoke had a bad scratch in the seal area....so tomorrow I'll get a new yoke & seal & install it....then crank it up!!!!!!!!!!!!!!!!!!!!!!
*starts practicing his best Frankenstein impression for when you do*
Ja Ja zee SBC!! Sur Gut!!! Das '36 Will live! i fear though that i will miss it. will be driving most of the day to go to a meet an greet in the twin cities for TRS/RF. i want Vids DG unless zee cam goes Stupeid:icon_twisted: then pics will do:icon_rofl:
The driveshaFT IS IN (again)!!!
Just Plain  Stupied
I'm gonna check all the flud levels....put some coolant in the radiator for these harsh Louisiana winters (Baaaaahahahahahhahahhaa).....
And crank it up while it's on the jack stands to eyeball everything....will try to get some decent video.....
Later.......
It cranks....
It starts......
It runs......
It rumbles outta the Harley mufflers....
It shifts......
The wheels spin......
Now to get the jack stands out from under it!!!!!!!!!
Junky *********************************camera!!!!!!!!!!
I'll get my daughter's camera tomorrow & get some video....hopefully
60 eh? maybe time to invest in ahh winter home in nawlins
First off thank you for your service to our country!
That has to be one of the most whacked, bad ass builds I've ever seen. You are a man with great vision and an incredible eye for detail!
