- Oct 19, 2008
- Regina,Saskatchewan
so my trucks idled like a POS for quite some time now, with periods of functionality. the problem is shown here:
IDLE PROBLEMO
so the problem is that it hunts for a medium but just goes up and down, almost stalling, until it jumps back up and high idles again. i've changed: tfi, plugs, cap+rotor, air idle control, map sensor, and checked some electrical connections. also, recently, its begun having difficulty starting. it cranks over for nearly 60 seconds sometimes, which is rediculous. the starting issue was not an issue when this video takes place, which leads me to believe its not necessarily, but possibly related to the erratic idle.
so today i did a self eec test, and what i got was this:
6blinks.short pause, 7 blinks, short (but slightly longer to signify seperation of numbers) pause, 6 blinks, then 7 blinks, ie code 67, then a longer pause, then 1 blink, pause then 1 blink, pause, then 1 blink, pause then 4 blinks, pause then 1 then 4, then 9 then 5 then 9 then 5... so i have code 67 continuous, then a 14 and 95 memory.
before when i did this test before i didn't get the 14, and this was all before the starting issue arose. so it leads me to believe the 14 and the starting issue are connected, although the black negative that branches from the main wiring harness on the passenger side had a poor connection that i fixed today, and this may have triggered the code 14. it mentioned something about causing the vehicle to stall, which it did, but i managed to get it fixed so its all good now.
also, after a long attempt at a start, the truck smells like gas, and sometimes i get some white smoke. i thought maybe a very small crack in the head, or something, but my dad says no it cant be.
so if anyone can help shed a little light it would be very nice. cause i either get this fixed or next month im gettin a brand new gmc, hard as it is. (me bein a ford guy and all, but the loyalty aint worth 15 grand)
IDLE PROBLEMO
