- Aug 11, 2007
- Age
- 70
- Ontario, Canada
- My credo
- Love Thy Neighbor
Good to see you used the blue rubber gasket...that's what stopped much of my oil leaks...and you can reuse them...but I'd not recommend removing the valve cover again unless you really need to...the rubber stretches...it might shrink if you dunk it in ice cold water, but haven't tried that myself...
As for the sludge in your cooling system...mine had the same amount of crud...and it comes mainly from using too much water...and not the proper mix of anit-freeze...but mine was probably together for more than 10 years without being properly flushed...so quite a bit can accumulate...
Oh, btw...you're engine has so much shine to it I can hardly see some of those pics...
