- Aug 27, 2007
- Age
- 40
- Minnesota
Well, the older brother and I took it for a test run, and a bunch of codes shot out. There's also an Idle issue we're trying to work out. And there's a small leak on the T-5 between the tranny face and the bellhousing, it's either a leak in the retainer or(hope not) a crack in the case.
it looks goofy as hell with the wheels your running and its just seems like its a hokey quick fix. everything else looks great so far and I can't wait to see some burnout vid's
The bearing cap. It's leaking out of the edges, I don't know if not enough RTV was used or if the hole in the case is worn out, I don't know.
. great truck
