Rev it up!!
Here's a second vid of it reving a little. Again, idle needs adjustment and I needed to hold it at 2000RPM since it's a new flat-tappet cam.
For the record: The sound is not inline with the vid, when he blirped the throttle body, the power was instant, but for some reason, the sound is laggin behind the video.
Yeah, like, not even two minutes after the truck was off, there was a
POOF!!, and the top hose blew of and rained fresh coolant all over the pass. side of the motor bay.
It sounded like opening one of those Monster XXL cans(has the twist off top), Not good. At least it wasn't the bottom hose, or
ALL of it would've emptied out.
You have no idea what a help my brother has been. He found out that the 92 ranger has a fuel relay under the hood, but the 89 mustang(wiring harness components) had it under the driver's seat.
So, we were stumped for a little bit. But he Googled a mustang wiring diagram(in color), bought a $30 relay, and professionally spliced one in under the hood. It looks factory(all if it does
), so it goes to show that after 1991, Ford put the fuel relay under the hood(where it should be!
), where as 1991 and before, had it under the driver's seat.
See? Learn something everyday.
