- Feb 8, 2009
- Omaha, Nebraska
To get your wiring into the box PICK A WINNER , 1cf should be close for most 12s, mine needs .8cf. I can't understand the rest of what you’re asking but I'd not build the box till you have the sub in your hands.
Do the connectors really matter that much? Should I look for gold plated? And does location matter?
I was asking if I should put the cup in, and attach the wires on the inside and have the wires sticking out of the hole that was cut out for the sub, hook them up to the sub, then sit the sub down in the hole, screw in, and go?
wow alot has gone one since i left lol.... first the book shelf speakers..........yea........second 1 CF for one 12 is a pretty good number,
porting- to port a box to specs you have too;
1 build the box to the right size,
2 have the dia or the size correct,
3 that the length of the port right, (its not just a hole) that tube is a certain length for a reason.
4 some times they want the hole 90deg from the sub, or on the same side as the face or the sub ect
i think i will just go sealed, i don't think I have enough room for a ported box unless i'm doin like an 8 lol.. and i want some deeper bass than that.
and i am not going to build the box before i have the sub, just trying to figure out how to be able to know what the max mounting depth can be.
