INFO Photos of Lifted RBV's With Different Lift & Tire Sizes
3" body lift
2000 Ranger XLT: Slight Torsion Bar Crank and 3" PA Body Lift on 33x12.5 Procomp ATs
2000 Ranger XLT: Hellluva Torsion Bar Crank and 3" PA Body Lift on 35x15.5 TSLs
How long did it take to put on your lift and how hard was it to do it?
Im planing on buying a 3" body lift also.:headbang::icon_hornsup:
here's my 91 with a 5.5 superlift and 3" body lift sitting on 33/14.5/15s
89 ranger
Here's my beast, 89 Ranger Custom 2" lift coils, Doubled leaf pack arched running 31's on 15x8.5 cragar rims.
Here is my 91 with the 4.0L weighing almost a 1000 lbs over the weight on my insurance after the Skyjacker 6"spring into 4" lift kit and Belltech shackles 2" Trailmaster lift block 1050 lbs leaf pack w/add a leaf on 33" TrXus M/T sits (yes I KNOW I have to trim the back of the fr wheel well openings)
[/IMG]
[/IMG]
just wondering
I got a 94 4x4 I want to put a 3" Body lift with some 33" tires does anyone know if it will work with little to no trimming? I didnt see this set up in this thread so if anyone knows that would be great.
thanks
thanks
I'm pretty sure I posted mine... I had 33's on my '93 with only coil spacers (1.5-2" of lift), but that took a little trimming to the backs of the front fenders (I just pounded it back a little with a sledge hammer, and the fender flair covers it, so it looks untouched there), and a little on the lower corner of the bumper (liek a 1-2" triangle). I'd say with a 3" lift, you'd be fine, or would have trim off VERY little, with the right wheel dimensions of course.
Look in the tire and wheel section and you will probably find more info from people who did the same thing you are wanting.
EDIT: Look at post 80, on page #6. Post 85 page #6, has less than a 3" lift, and 33x13.5's. My pictures are on post 94 on page #7,
4 inches of lift with bald 31x10.5s
the same truck with 33x12.5s and same 4 inch lift with fender trimming in the front and soon the rear.
1996 ranger 4x4 4.0L 5R55E 1354E, 6 leaf, ranger/explorer combo, skyjacker 6" stage 1 lift, 1.25" spacer block in front, 3 BL performance accessories brand, 35" BFG MT's
3" PA bodylift, torsion crank,33x11.50 nitto mud grappler, 16x10 wheels with 4.5 backspacing
94 Ranger 2wd with 2" coil spacers and Exploder leaves with an add-a-leaf.
235/75 15's in the front and 30x9.50 r15's in the back.
88 B2 - 2" coil spacer and rear add a leaf. Running 30x9.5/15 Goodyears. The only rub I get is the right front tire slightly rubs on the sway bar at full lock.
Derek
I've got that same lift. I got mine off ebay. My truck already had the stock STX highrider lift,plus 2" trailmaster coils and 3" blocks in back. I put the 2" coil spacers and the 2" add a leaf. I call it the po-man's lift. :P
