Update on my 88 Ranger SAS
Thanx for the links and pix. i haven't found any ranger sas kits yet,only toyota. looks like i have to measure my frame rails and compare the width to toyota. i want this soo bad! and after seeing your truck- i know its possible, well i mean .....streetable....unlike progectnightmares with the rockwells,lol. his truck is insanely killer cool .
looks like my truck....from a few years back
Did he actually get those under his truck yet? I knew he was thinking about it but wasn't sure if he went ahead with it.
he had some pix of his rockwell progect up before TRS changed everything on us. i dont know how far he has gotten with it yet. im sure he'll post pix when he's done. i can hardly wait.
How much lift springs did you put up front ? how big are your tires ? i just sent a picture of your truck to the ruff stuff guy so he can put a kit together for me. well , i mean for us guys here. after your motor and trans get in there .....whatta you thing your headlight height will be ? just trying not to be higher than pensylvania's lift laws. i might have to use a smaller spring.
i used superlift chevy 6" springs... they are a little stiffer then i wanted but i got them for 50 bucks from a friend, those are 36x14.5 inch tires on it now im going to run around a 40 inch tho when im done. i would use some 44044 or the RS44044 if you want a lil smaller. not sure on the headlight highth
what kinda kit are they making? i would just make it youself, steel was only like 50 bucks for everything to make it
he was telling me that i could use the toyota cross leaf spring stuff and fj40 stuff. i spent 20 minutes on the phone with him today and he was able to determine the amount of frame drop from the 2 measurements he told me to take. the base of the front frame and behind the wheel . both measurements were from the frame to the ground. he's not charging any extra to itemize everything i need to complete my progect based on the experience that he's had with other ranger owners. and 10% off all parts purchased = not too shabby.
sounds good man, post some pics of your parts when you get them
You got it . it might be a little while because ,"the bucket i keep my money in has a hole in it" ,lol.
Looks good, keep the pics coming!
thanks,
still workin on building crossmembers... in the process of building that Got trikes tube bender... plans look awsome and im gathering supplies for it will post pics on that as i start aswell
Cool build!
Got anymore pictures?
what you want pics of? i got hella but my computer is slow so i only upload what i have to
Could I get some pictures of the Front Crossmember, and the Front Shackles. (Basically the front buildup of the truck)
here ya go
it looks a lil better now (its fully painted, frame and body)
it still needs to be gusseted all over the front hanger
i think i made it all for around
100 bucks in metal for front hanger, shackle hangers and shackles
400 axle + 75 machining on knuckle and 100 for ball joints
60 bucks for springs
