Just Plain Stupied
doorgunner, just put a fuel pressure regulator just before the carb, turn it down to roughly 6 psi. then your good to go.
Make sure it's a return style regulator as well. Won't know how well it will work, but I am going to try this on my carb swap too. If it doesn't work out, I will likely get an aftermarket Holley fuel pump and use it with the regulator that I have.
Just pulled my 2.9L last night as well, took 7 hours said and done...
Pete
thanks for the info
/let us know how it works(or not).
I'm tryin to keep everything OEM in the fuel systemplumbing
/Ijust wanna add in the carb-regulator while the sbc is in the Ranger til I rebuild the 2.9
(cept for the bad headgaskets, I'm hopin it's in good shape)
--bet ur glad to get the 2.9 outta there:headbang:
just tired?...............o-o-o-o-o...I git it..w-aaaaahaaaa-hhaaaaa-old-man-cough/wheeze...wa-a-ahaaa-haaa-ha (man, I'm startin to laugh like blackwidow:icon_surprised:)
i find that insulting. :icon_surprised:
na-a. your part is is the great wa-haaahaaahaa:headbang:.
my part is the ole-man cough--wheeze.
you see, when i try to do the great part--it takes the strength of an 18 year old,
but my 85 year old lungs caint handle it:fie:
my cab/running chassis has been in hiding for a couple months waiting it's turn for bodywork-paint behind the '69 Camaro while I worked on the sbc for the Ranger.
The Camaro is finished :icon_bounceblue:
i'm next :yahoo:.
gonna go Monday & try to get some pic's of Expert Collision's work on the Camaro paint...
EDIT: no pics of the camaro paint--the owner picked it up before I got there
Just Plain  Stupied
Just Plain  Stupied
[/URL]
Note to me: use whitetrashdoc's crank-start idea/modify it by using a Ford crank-handle thru the lower radiator grill w/spring-loaded switch wired thru neutral safety switch to starter solenoid/switch to stay activated as long as handle is cranked(just for fun).:yahoo:
Note to me: check out FatMat sound deadening (recom'd by blackwidow67).....check
Note to me: install adjustable thermostat to electric fans.......check
Note to me: use return regulator w/fuel pressure gage b/twn carb & oem regulator.....check
Note to me: undercoat all body parts before assembling........check
Note to me: Rotate/ shim rear axle to match angle of rear drive shaft to stop differential from
bucking on take-off......check
Note to me: order door seals & fender-to-body & hood-to-body anti-chafing gaskets
Note to me: wire & install back-up lites............................check
Note to me: buy a fancy gas cap lid to put in the bed floor......WHAT???.........check
Note to me: don't mess with the new Moderators.....check
Note to me: center wheels in wheel-wells.....check
Note to me: install front/rear adjustable air-shocks................check
Note to me: re-connect 3 vacum lines................check
Note to me: weld support plates & tubing to ends of roll bars under cab & bolt to chassis
Note to me: add 2" thick soundproofing through-out cab before installing inner walls.....check
Note to me: splice in remote start/alarm/doorlocks b4 wrapping/tucking driver's side wiring under dash.....check
Note to me: test out oem versus Classic sending unit BEFORE installing in the tank (b-b-bo-o-o-m-m-m-m)....check/uncheck...gauge works, but won't go all the way to Empty(modified float arm)......check
Note to me: weld chrome Harley mufflers to exhaust pies before somebody steals em....check
Note to me: use whitetrashdoc's crank-start idea/modify it by using a Ford crank-handle thru the lower radiator grill w/spring-loaded switch wired thru neutral safety switch to starter solenoid/switch to stay activated as long as handle is cranked.:yahoo:
i smell a new "just plain stupid" thread. :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl: :icon_rofl:
couldnt'a thought of it witoutcha:icon_idea:
---teamwork:icon_hornsup:
'scuze me while I find the old sketchbook:D
Thanks Wicked--I hid some of the parts to keep em scratch-free/the other side of the room gots more ..
Just Plain  Stupied
:headbang:
Nice body panels - of course the wife was looking at everything else like your wooden floor and the stand/table. She wants to see more of the house - lol:icon_thumby:
More
Just Plain  Stupied
gotta go--my wife wants me to go look at something:3gears: :icon_surprised: :yahoo: :drool:
Her first comment was :icon_surprised: WOW - she was wondering if you have a lot of antiques - nice . . . :icon_thumby:
Thanks! but the only (other) antiques I have are the Ranger & me:icon_rofl:
Gotta go....my wife says I'm lookin at too much truck porn.:icon_surprised:
Waaaaaaaaaaa-haaaaaa-haaaaa-haaaa.
EDIT: 3/11/09 Wheeeere's my running boards???
tell your wife I found the running boards under the bed
/she oughta get a kick outa that:icon_rofl:
DoorGunner,
That is an awesome project, please post pics when it's all together, so we can all enjoy it!
John
John....thanks.....
Doing some bends for the back of cab to fit on each side of rear window (red-neck bender needs to be mounted on a work bench now that I know it'll bend .200" wall pipe:
Now to lift the roll cage until it touched the insulation and clamp it into place while i weld the frame braces in place. The rear cross-bar should fit right under the rear window.....
Tacked a few pieces together to see if I'm headed in the right direction.
  • Just Plain  Stupied
