Sale pending on the Iroks...
I got my chromos and lockrite in today, so I went to work installing them. I had to first pull the thirdmember out of a spare rear, that had a leaky pinion seal and bad pinion bearing. So I sacrificed this third for the sidegears, which are 26 spline, as opposed to the front sidegears which are 22 spline. The chromo axles are 26 spline and match the diameter of the rear axleshafts. I needed the sidegears to go with the locker, because the sidegears mesh better than the optional couplers they sell.
So I got the sidegears swapped out, locker installed, and the third back in the housing, and one of the shafts slid in. It's quite an ordeal getting the new birfs into the ball on the housing.
I'll finish the rest up tomorrow night, I want to repack all the bearings, and change out the other seal and felt on the drivers side, the passenger side I just did when I swapped out the last broken birf.
Aside from my near future motor and trans swap, I'll be pretty much done with the mechanical of this rig, and ready to start on the next one.
I still want to add a little more body protection up top, but I don't want to go with a full exo, maybe a couple strategically placed slider bars.....
Then it'll be done.... for now.....
Anyways, enough of my ramblings, I'll reward you with some pics.
This is the start of the new project. 84? Suzuki Sj410 (still pre samurai) with the front half of a tin top grafted on. I'll be enclosing the back wall, and making somewhat of a pickup out of it. Enclosed for winter wheeling.
Birfs: New vs. Old
New vs. old
Swimming for sidegears.
The tiny little sami lockrite.
26 spline sidegear on 26 spline axle
26 spline sidegear on 22 spline axle
Where I left off tonight.
Interesting note* these are the 22 spline sidegears I welded to "spool" the front originally. These have been abused and have seen two broken birfs. I've been running them for about a year.. HARD. As you can see, the spiders have started compressing the welds, but aside from the indents, there is no visible stress or wear on either the spiders or side gears.
OK nuff for tonight.
