- May 31, 2008
My ABS light is lit and when I pull the codes I get code 12 which I believe is brake fluid level low. WHen I check the fluid level visually, it is fine. I am assuming that the sensor has gone bad and have researched it and as far as I can tell, The sensor isn't available without purchasing the entire master cylinder.
Therefore, I would like to bypass the sensor so the reservoir appears to be full to the ABS system. The sensor has three wires coming out of it, one of which appears to be a ground. Does anyone know how to wire them up to bypass the sensor?
Thanks in advance.
Thanks in advance.
