- Sep 18, 2008
let me know if you need any help with the build man ive been there and done it to my truck
you might need to buy some tools for the install also.
- You will need a 1-1/8" wrench for the lower coil spring nut, the radius arm to beam bolts, and the rear radius arm nuts.
- You will need a pitman arm pulled. Most auto parts stores loan a tool program loans these out.
- You will need a tie rod seperator. Again, you can probably rent this from a parts house.
- You will need an angle grinder with grind/cut off wheels for the passenger side beam and radius arm bracket rivets. Get a couple cut off wheels as you will use atleast 2.
the pickle forks work great unless your trying to save the tie rods them selves, it pretty much runis the boot on them and might pull the ball out fo the cup if they are worn enough.
Two big hammers. a couple of hard hits to either side at the same time and they pop off pretty quick. Hit the metal where the stud it. it impacts the taper and slightly distorts the hole enough to pop it off.
Works every time and no damage to TRE or Boots.
If you don't have at least an impact, get one BEFORE you start the lift. Also, a 1-1/8" socket will be handy for that impact on the radius arm bolts.
