Advice Needed: Low compression on cylinder 1
Featured Build Threads
Thew
Forum Member
Seattle
N/A
Vehicle
Drive
~275k miles on my 94 3.0 4x4 with the 5spd. Its a great little truck, I've put loads of work, time, sweat, and tears into it. It starts right up every time and has done everything I've asked of it.
I got the truck at 260k, previous owner had just put new heads on it and stated they did a valve job (16 yo kid and his older brother, so who really knows). Also was told that the owner before them had all the seals redone (would have been 3-4 years ago now, not sure how accurate this info is).
When I got it, I pulled and ported the upper and lower intakes (replaced plenum with a two piece style off a taurus), cleaned and rebuilt injectors, new plugs and wires, rebuilt the distro, new ignition coil, cleaned MAF, new IAC, new TPS, flushed coolant system + all new coolant hoses, new timing chain, fan clutch, water pump. A fair bit of work to try and ensure it would run well for the next few years.
The idle has always been a bit off, sometimes fluctuating a couple hundred rpm, but otherwise seemed ok. I checked for vacuum leaks and couldn't find any. Over the past year and a half I've had it, the vibration at idle has increased, but the excess vibration goes away under throttle and she runs just fine with the pedal down. It does have white steam/smoke out of the exhaust usually until it warms up. I've normally chalked it up to moisture collecting in the exhaust. It doesn't drink coolant, but does drink a quart of oil every 3-5k miles. I run seafoam in the oil a few hundred miles before every change. I use 5w-30 Valvoline maxlife high mileage full synthetic and wix filters.
I drive fairly aggressively (not the most fuel efficient) but I still get 12-15mpg around town and 16-20mpg on the highway. Pretty normal for me with other v6s I've owned. For a lifted 30+yo truck with 32" tires, can't complain too much.
Did a OBD1 KOER test and cylinder balance test a couple nights ago and came back with a weak cylinder #1.
I finally did a compression test last night, and the results are a bit concerning. Was done with engine warm, fuel pump relay out, all spark plugs pulled (plugs all looked good and the same across cylinders). All cylinders were within 5psi of 150, except cylinder #1, which was 92. I added ~3ml of oil through the spark plug hole and tried again, 105psi. Added ~7ml more (about 10ml total), and it shot up to 150 psi.
By my understanding, this indicated an issue with the rings/cylinder wall not sealing properly. Is there anything else it might be or anything else I should test? If it is the rings on that cylinder, is there a way for me to repair it other than a complete teardown of the whole engine? Would a leak down test tell me anything else?
It's my daily and my only vehicle so having it out of commission for a while would be not ideal. An mTDI swap down the road would be the dream, but may be too big a project to take on at the moment. Any insights, wisdom, and ideas are very much appreciated.
sounds exactly like my truck before i decided to swap a v8 in it the last hope i would say is a burnt valve seat but most likely scored wall or bad rings i would say
nah thinking about it wet test would only indicate rings or walls so 16yo kids valve job seems to have held up
Could be just stuck ring on that cylinder, stuck to the piston and not pushing out to seal.
Could try and loosen the ring while installed, maybe pour diesel down the cylinder? Someone else might have a better idea.
Could also pull just that piston and replace the rings. Could probably be able to do that with the engine installed.
Stick a scope down there and look at the bore. Cheap in the jungle website w/ decent quality camera.
atf?
I think I'll start here and see if I can see any obvious damage or scoring. It would be lovely it was just a stuck ring, fingers crossed. I was shocked at just how low the compression was when every other cylinder was so similar.
Thanks fellas!
Unfortunately it sounds like #1 was the first to get wore out and tired after 270k. When you check it with a bore scope, if you don't see a bunch of vertical scoring, have someone with a wrench rock the engine back and forth to see if there's excessive movement of the piston.
Took a peak inside the cylinders with a borescope. Quite a lot of carbon on all of them, but the walls looked decent.
I’ll try some seafoam spray, first through the intake and then likely again but through the spark plug holes and let it soak for a few days. If that doesn’t work, I’ll probably try acetone/atf. There may be hope yet
  • Advice Needed: Low compression on cylinder 1
The majority of the wear will be a little bit lower than what is visible with the piston that high. But honestly I have a cylinder that is 150psi and looks way worse. That valve looks a little suspect though. It doesn't seem to have a visible wear mark from contacting the seat.
A vacuum gauge will tell you if it’s a bad valve or seat. Just watch the gauge and if it rapidly bounces at idle, you have a valve issue.
Event Coverage
Featured Ranger Based Vehicle
