4.0L OHV 2.9 rockers on 4.0 heads. anyone done it?
Featured Build Threads
FildoDagginsRHEC
Commack
NY - USA
unknown
TBD
TBD/33"S
Raise Hell & Eat Cornbread
I had read somewhere in this goldmine of ranger info that is TRS.com that "the only way to get ride of the 4.0 ohv valve tick is to get the heads milled to accept the 2.9 rocker rails.
now, I have brand new clearwater cylinder heads for the 92' 4.0 I have.
I also have [2] 2.9 motors 86' & 88' CA emissions and a 76' 2.8
has anyone done this? put the rocker rails from a 2.9 onto a 4.0?
anything specific I should look for in doing this?
Installing the 2.9 rocker system is a improvement? They had and have plenty of ticking and oiling problems with the 2.9 also. Looks like the 4.0 receives oil on top just like the 2.9
I found the information I was looking for...
user gaz suggested it. just like to see if anyone else has done it or has heard of this.
If you read that thread more closely, he said the rockers from 86-88 are the same, he was just using 2.9 rockers because he had some laying around. Sounds like he was basically "blueprinting" the valve train, to get everything in spec so the lifters had plenty of adjustment. And also modifying the oiling for more oil flow to the rockers.
Ford and other OEM's have a tendency to throw things together at the assembly plants, calling it good enough. If the vehicle lasts good enough, 5 or 6 years, that is good enough for them, since most people do not keep vehicles very long before they buy new ones.
Isn't there a kit (Maybe Morana) with adjustable rockers out there? Seems like that's be the best thing, but then you have another regular maintenance item.
I thought they were already adjustable(at least on the 2.8 and 2.9). What is that little screw and locking nut I have been turning on the tip of the rocker?
Event Coverage
Featured Ranger Based Vehicle
