Cylinder 3 Tick at Spark Plug
Featured Build Threads
bjkeeling
Forum Member
Vancouver
BC - CAN
Vehicle
Drive
Got a tick, listening with rubber hose it's definitely around spark plug #3 recess. 2005 Ranger 3.0L V6 RWD, about 309,000kms. Curious if anyone had a similar case or diagnostic suggestions/resources before I pull the valve covers.
Injectors all sound okay, I know two of them have hairline cracks in their plastic bodies - believe they're on cylinder 1 and 2, not sure tho - they were under the upper air intake (bank 2) and I moved them to bank 1 when doing the head job to simplify access if they became an issue; injector delivery didn't come in time and the old timer who let me use his shop suggested it wasn't that major a concern. I'm not hearing anything particularly evident at the top of the passenger valve cover around cylinder #3. Tick is very definitely most audible in the spark plug #3 recess. Swapped spark plug #3, replaced spark plug wires (they looked worse for wear) and even got a new ignition coil pack. The tick showed up hour 2 of a 12 hour drive moving from Calgary to Vancouver hauling a 4'x8' trailer; didn't notice any loss of power, and finished the move with no problems. Truck is mostly sitting, while I try and get this sorted. Did get a P0430 (suggesting bank 2 cat is toast, or new O2 sensors are faulty) and a P0340 (CMP circuit malfunction) right before I picked up the U Haul trailer - reset them and a few days later only the P0430 came back. Camshaft syncro was just starting to whine, gears looked fine, replaced it as I had the part handy (had it out a few months ago, definitely didn't make this noise then). Tick seems to go away when I unplug the coil pack (RonD wrote somewhere if you cut power and the sound continues it's mechanical, eliminating the ignition system), but it also seems to reduce in intensity as the vehicle builds pressure / warms up. Can't hear it in the cab when idling, but can above 2,000rpm. My first gut reaction was a lifter tick, making me want to pull the valve covers, until I hear it only around the spark plug 3 well. My dad's old Crown Vic ran for ever with what I could swear was this exact noise.
Wondering if I should swap the old O2 sensors back in and do a test drive watching the downstream O2 sensors and see if the levels become less erratic. I don't see how this could be related, bank 2 is for cylinder 4,5,6.. but that's a whole lot easier than dropping coolant and pulling the valve covers / rockers / lifters and should be done anyway.
I expect I'll pull it into the garage on a Friday night in a couple weekends when the girlfriends out of town, pulling the fan to run it with minimal noise Saturday morning for a minute or so and see if I can hear something more diagnostically useful, before getting into pulling the valve covers to check if a rocker seems off and inspecting the lifters if I can spin the valves and the rockers seem properly preloaded.
Recent work:
May - head job - exhaust valves were recessed, had a shop address that and reinstalled heads, ran better than ever about 5,000km since
August - compression test - all 152.5-165, wanted to decide whether to invest in body work / keep the truck. The next day she died on me suddenly. Turned out to be a MAF sensor, looked like rubber material (gasket material from air filter?) Initial diag had me thinking timing, pulled the timing cover, damaged the oil pan gasket.
Decided I wanted to keep the think, did rocker panels, replaced O2 sensors, and fixed the leaking oil pan gasket with probably too much RTV.
Drove 3,300km - no qualms except lack of AC (on the list).
What has me stymied is why the tick is so much louder in the spark plug #3 recess if it isn't spark/ignition related. The exhaust manifold bolts are recently replaced, manifold seemed solid. Before the head job the bolt on that edge (nearest spark #3 recess) of the manifold had already broken - seems like a common issue when I was looking up head job resources. I've inspected it running at night (under street lights) and don't see any arcing.
What has me worried, is the excessive use of RTV on the oil pan gasket tear, instead of properly replacing the oil pan gasket (read you needed to raise the engine), and whether it made it into the small hydraulic lifter passages. It was Permatex's The Right Stuff, which cures in an hour, think it had about 6 hours cure before a 30 minute test drive and sitting for 24hrs+. The Ranger serves as my girlfriends daily driver, so I want to ensure it's reliable and will last us as it's kitted out to camp with. Will work on cleaning up rust and undercoating it in the coming months when hiding from the winter rains once I get this sorted.
Maybe an exhaust leak?
Those sometimes make a ticking/tapping sound and the flange is right there by the spark plug. No combustion when the wire is pulled would get quieter or disappear, and it would get louder with engine RPM.
In know you said that the heads were recently off, but if the manifolds weren't tightened properly or a low quality gasket was used, they can burn out in short order.
Just throwing it out there as a possibility.
I agree with an exhaust leak around the manifold. If it seems to quiet down with no combustion, it could be around that exhaust port.
Thank you, gentlemen, for taking the time to read and comment. I used the ENGINETECH F183HSC head gasket kit off Rock Auto, and look identical to these.
Fair point - loosening the exhaust manifold and having a sneak peak should be easy enough - all bolts/studs have anti seize. I think I did check to see if they were loose, but didn't thoroughly inspect. I definitely didn't use a torque wrench when tightening down the manifolds, but at 20 ft-lb spec I made sure they were snug with a normal length 3/8" ratchet and moved on.
Will report back in a couple weeks.
You might be able to use your phone to record a video with the flash on to look underneath the exhaust manifold so you don't have to remove it right away. Might be able to see a black soot trail somewhere to confirm a small leak.
After throwing parts at it vis-à-vis ignition, I'm hesitant to just keep changing parts without diag pointing in a direction. I did have a look underneath (and above), and didn't see anything that appeared to me like an obvious soot trail, but maybe I don't know what to look for. I did start by loosening off and then retightening per spec the exhaust manifold bolts to no avail. The passenger manifold bolts are not seized, and the manifold is not stuck to the head. I then pulled the valve cover, and none of the lifters are noticeably collapsed, no noticeable play in the rocker arms, and the rocker arm bolts are torqued to spec. Three or so push rods spin pretty easy when the valve is closed (cylinder #2 intake / cylinder #3 exhaust valves most noticeably).
Listening to Youtube videos, this noise definitely sounds like an exhaust tick over a lifter tick. Here's a video with sound - at the 30 second mark I put the phone mic right up to spark plug #3 well where the noise is most prominent. I inspected the manifold more closely and I don't see a crack on it, but did find scaling that came off easily with my fingers near the bolt points to the head - maybe soot build up? I forgot to take photos, but the video at the end kinda shows it. Paired with the weird O2 readings I saw and the code for the cat, I figure I should get my hands on some manifold gaskets before I inspect / pull that apart. I think I recall minor pitting on the mating surface of the exhaust manifold, and intend to use the slightest skiff of red RTV on reassembly if I do in fact find that.
Rock Auto only carries drivers side exhaust manifolds. Looks like there's a couple auto recyclers near here if it's more than gaskets.
Any suggestions/preferences on an exhaust manifold gasket? Fel-Pro, Ajusa, Victor Reins (oval OR round port style), Apex, and Mahle/Clevite are the options Rock Auto carries. I'll call locally but Rock Auto is always cheaper and I'm not in a hurry. Putting a parts order together, need to do the girlfriend's brakes, get some oil filters for the shelf, etc. Thanks for any input and for taking the time!
thinking outside the box, at least this is cheap stuff.
in total darkness shine a small flashlight around the manifolds looking for a burst of exhaust.
maybe spray some mist to catch the burst?
use some small rubber hose as a steth-o-scope. you can put a short piece of tubing at the probe end to protect fingers.
you can get real close to noise sources by using a small hose.
oh, blow thru the hose first to clear out spiders.:shok:
lifter & valve train:
take the oil filler cap off, any noise in there?
harder to get to, take the PCV out and hold the hose there.
Being in Michigan, I always dread bolts and studs related to exhaust. I've been putting off replacing my rear main because of the 2 exhaust flanges on the Y pipe.
I like the spraying idea - to watch the aerosolized particles - useful around the manifold mating surfaces, manifold itself, and other joints - thanks (y)
already been using ~1" tubing to pinpoint, but I don't have a smaller hose, will take a look but likely would have to buy something - it's loudest at the spark plug #3 recess - and I have no reason to believe spark plug #3 isn't seating properly
Already took off the filler cap - nothing; PCV is on the drivers side, this noise is passenger side
other than heat, you can drill into the nuts to weaken them, then hit with chisel to split. it's not very easy to do.
the joint between the Y pipe and cat will also be hellish.
I did the heads in May, and covered the manifold studs in anti seize on the off chance I'd ever have to go back in... so the gasket won't be too bad, it's the manifold to exhaust pipe joint that scares me, if it ever comes to swapping the manifold
Truck has been living north of the rust belt for the last half of its life, and the bed frame rails show it it's benefited from it. Parked it last winter in Nova Scotia where salt from the ocean is in the air, and it noticeably aged.
sounds like a good place to start misting.
So, I went ahead and swapped out the passenger exhaust manifold gaskets, cylinder #3 was burning out on the backside. Tick is gone, and its not currently throwing codes. Manifold is easy enough to access, will watch and wait on the driver's side - had other chore priorities today; will probably loosen the manifold bolts torque them down 'more better' the next time I tinker. Now I need to figure out where my AC leak is, before summer shows up, haha.
  • Cylinder 3 Tick at Spark Plug
It's a good feeling when you replace something knowing it is going to fix an issue. Seeing the exhaust gasket leaking would have made me smile if I was in you shoes
Upcoming TRS Events
Featured Ranger Based Vehicle
