2.3L ('02-'11) TPS issues looking for guidance
Featured Build Threads
Wiggle the tps connector while you sweep the throttle with forscan hooked up again. You should see if there's a bad connection. Also make sure the throttle shaft isn't over rotating the sensor. Unbolt the tps and hold the throttle wide open. Slip the sensor over the shaft and rotate it by hand to see if the bolt holes line back up.
No connection loss when I wiggle the connector or the wires
I think I did the test you described correctly? If so everything lines up and looks fine there
That sounds right...
So why doesn't it reach WOT when it's bolted on? Were you moving it by hand at the throttle body or pushing the pedal in the truck? Maybe you've got the classic cable stretch?
I was moving it with my finger at the throttle body in the sensor itself
...I'm looking at my voltage numbers in the graph I posted and at closed it reads .63 and at WOT its only at 3.83...
Just not sure why you had this result earlier then...
I dont understand either . Bad throttle body? They're discontinued. I have one out of a junkyard when I did my intake swap to the one without the swirl plates. 🤷‍♀️
  • TPS issues looking for guidance
Kinda makes me wonder if the post earlier your 5v supply going low wasn't correct. It's just intermittent. If so what's causing it?
Hopefully someone will chime in with some ideas lol
You moved the TPS sensor with your finger, and where able to get the correct voltage readings the computer is looking for. But when you bolt the TPS onto your throttle body and use the throttle arm to check the tps voltage, you do not get the correct readings. Seems like this is the crux of your problem, and it seems like it would be mechanical with the relationship of the tps to the throttle body.
I would get your meter on the tps, with the tps mounted on the throttle body, no throttle cable hooked to it, and move the throttle by hand while watching the meter. Just keep staring at it and thinking what could the problem be? Is it going to come down to taking a dremel tool and opening the holes up a little bit on the tps? If this new tps is made in china, it certainly is possible they made it wrong and it will not work correctly without modification.
The cheap ones I've seen (granted only a couple) HUGE dead zones. 0.9v from 0-20% then normal to 80% there and up is 5v. Seems like it would make for awful throttle response.
with the TPS connected your lowest voltage was .63
when it was hanging loose it only went down to .72?????
the 5 volt input should always be 5 volts, no variations. if the 5 volts varies the signal output will also be off.
ground always 0
output varies between those 2, within the limits of the variable resistor.
compare the angle of the throttle blade with the TPS slot at open & closed, do they match exactly?
is the slot a loose fit on the blade?
put the TPS on without screws, rotate it and throttle to limits, what readings do you get?
measure between the ground wire at TPS and negative battery terminal or engine block. should be 0.
When you turn the tps by hand to check the voltage readings, with a sharpie or tape mark the high and low position of the slot and see if it matches up using the pedal itself. Seems like something is off
Sorry yall. I am reading everyone's replies and appreciate everyone. More confusion: since I put the TPS back on Wednesday, the code has not came back and the truck is driving fine. I know it isn't permanent cause i've been dealing with this forever, i'm sure it will come back eventually. But I noticed when I was putting it back on, the bottom bolt hole is stripped and doesn't tighten down. It will get tight to a point and then loosen back up. So I just tightened it til right before it starts to loosen again.
I'm wondering now if that bottom bolt is loosening over time since its stripped and when the sensor gets loose to a certain point, it gives me the code and starts driving funny?
Literally since i tested it Wednesday and put it back in everything is fine and my voltages and everything is fine. Intermittent issues are the worst.
The brand I got is NGK. It was the most reputable brand I could find since the motorcraft TPS is discontinued
Stripped hole sounds like a plausible reason. I would put in thread repair. Heli-coil or similar.
Upcoming TRS Events
Featured Ranger Based Vehicle
