2.3L ('83-'97) Valvoline Restore and Protect
Featured Build Threads
oldgeek
Forum Member
USA
2.3L
I have been using Valvoline R&P for a while. Everything I have seen revolves around either the Valvoline videos or people posting oil sample testing. Although, Valvoline's marketing is focused on piston ring deposits. This guy did a teardown before using it and a teardown after 20K miles.
Can you give a synopsis?
Asked Gemini to do a summary.
Here is a summary of the video from the specified timestamp:
  • Real-World vs. Lab Testing [37:10]: The host notes that while Valvoline’s marketing and the 3H standard dyno test show aggressive piston cleaning at sustained 300°F oil temperatures [04:03, 07:22], everyday street driving [07:30] cannot fully replicate those conditions.
  • Engine Wear Analysis [26:35]: Used oil analysis over the 20,314-mile test showed that internal wear rates actually decreased over time as the oil ran, indicating the engine remained healthy and well-protected.
  • Post-Test Teardown Results [35:05]:
    • Piston cleanliness showed gradual improvement compared to baseline, moving in the right direction, though full deposit removal on a street-driven engine likely requires a much longer interval (e.g., up to 60,000 miles) [39:43].
    • The control piston (ultrasonic-cleaned beforehand) remained completely clean, supporting the claim that the oil helps prevent future deposit formation on clean parts [13:30].
    • Ancillary items like the timing chain cover, oil pan, and cylinder head showed minimal visual changes [32:04], but Valvoline's primary claims target piston deposits rather than external casing varnish.
  • Limitations on Oil Consumption [42:27]: The host explains that while Valvoline Restore & Protect can resolve oil consumption caused by stuck piston rings, it cannot fix mechanical issues such as scuffed cylinder bores or poor machining tolerances.
Upcoming TRS Events
Featured Ranger Based Vehicle
