- Aug 31, 2024
- Pa. USA
- 2.5L
- Total Lift
- No Lift kit
- Total Drop
- No Drop
- Tire Size
- P225/75R15 15x7.0 j stock metal rims
- My credo
- Diplomacy only works with Diplomatic People
Hi all,
Anyone who has a 98-2000 (and early 2001) Ranger 2wd with the 2.5L and bad engine mounts has probably figured out that the driver side mount part #- YL5Z6038BA has been discontinued by Ford.
Everybody sells 2 passenger side mounts part #- YL5Z6038BB as a set but the passenger side doesn't fit properly on the driver's side. It will raise that side of the engine putting a twist on the drive train. How much does it twist?
I don't know since I haven't bothered to put one in because it wasn't built for that side.
Unfortunately my mounts have deteriorated even more over the past 5 years so before I go to all the trouble of removing the OEM just to put the wrong part in, I was hoping someone here might have already figured out this issue.
Has anyone successfully used another mounting bracket from a different engine? Or what about the 2.3L mounts? Will they work on the 2.5L?
Can the OEM mounting bracket be safely modified to account for the different mount shape?
Here's some info I found on a forum somewhere.
Unfortunately I can't give the OP credit since I don't remember where I copied it from.
