Is what some people actually like?
I don't understand that at all, especially with a 5 speed transmission. My definition of high RPMs is basically anything over 3000 RPMs going with or close to the flow of traffic. Of course the flow of traffic has risen a lot since the 1970s 55 MPH was lifted.
My first few cars in the late '80s were air cooled VWs with tiny engines and 4 speed manuals. Adequate for 60ish mph. Long uphill grades required dropped down to 45 in 3rd.
My first modern car was a '78 Rabbit Diesel with a tired 1.5 and a 4 speed manual. Very similar to the air cooled VW, but a bit more power and far better fuel mileage. I sold it to buy a real car. A 1983 VW Rabbit GTI. Almost 100 hp and a 5 speed close ratio manual transmission. Very fast and fun, but highly annoying on the freeway. It would spin around 3700 RPMs on the freeway going 60ish. Just barely touch the gas and it would jump up to 75-80 almost effortlessly. Max speed was like 105 at redline. It could even pull that up grades driving to Lake Tahoe.
I was reading all the magazines at the time and learned about gearing. I put a junkyard 5 speed from a Rabbit Diesel into my GTI. Such an improvement going from a .85 or .80 ratio 5th to a .71 ratio 5th gear. I don't remember the difference in the final drive ratios. It cruised so effortlessly. I ended up learning how to repair the missing differential snap rings without taking the transmission apart and to add the .71 5th gear to it. That was a nice combination. 1-4 close ratios and a very tall 5th gear.
The reason I'm mentioning this is because my '78 Datsun 620 with a 5 speed is the same way as my GTI was before the transmission swap. Very low gearing so not comfortable on the freeway at all. Apparently it's got an early 5 speed and I need to look for a later one to get taller gearing, or maybe a 5th gear only swap. I brought that up on a similar Datsun forum and everyone said that high RPMs on the freeway is just what you want for a mini truck. Just drive slower if need be. Seems strange to me, especially when I told them that I wasn't towing or carrying any loads. I don't like sharing the slow lane with the semi's because my vehicle is "tached out" going 60 in a 70 zone. I don't want the same thing happening with my 1990 XLT 2.9 4x4 auto that I'll eventually swap to a 5 speed. I want to be able to effortlessly keep up with traffic and not be close to being "tached out". If I'm towing or carrying a load, I don't mind parking in the slow lane then.
