Featured Build Threads
My super expensive NAPA transmission jack leaks down. I need to fix it, but it’s not bad enough yet. Any jack can be a dud.
My favorite floor jack came from the scrap yard… it was just out of fluid. Filled it and it works perfectly. It hasn’t even leaked a drop in like 10 years. Makes me wonder why it leaked to begin with.
I hate to admit it, but bought these today.
Wanted a battery powered die grinder for some stuff I'm doing on the camper, and just general light duty stuff. I've got airpowered and a good compressor to run it, but that's not always very convenient. Really wanted to go Ryobi since that's what all my other battery power tool stuff is, and I've had good results with it. Unfortunately Ryobi's 18v battery is pretty big, big enough to be obstructive for this purpose, and the tool by itself is over $150. More than I wanted to spend for what I plan to use it for. Same story for the other brands around, large battery and/or high cost. Milwalkee would be similar in size to that, but don;t want to spend the money on it.
For $50 with battery I figure that this will do the job, and if it doesn't last, I'm not out much. Started to buy a second battery since I don't know how long it'll run on the included 1.5AH one, one charging while the other is in use. A 2AH battery is about $25, the drill with 1.5AH battery was sitting right under it for about $22. Seemed like an easy decision. I'd started to pick up a second Ryobi drill back during the "dealer days" sale at Home Depot just to have a small one to toss in a drawer in the house, but never did. Now I'vbe got one to toss in the drawer.
Unfortunately discovered after I got home that the grinder I grabbed must have been old stock. The battery with the drill is set up for USB-C charging. The one with the grinder is an older bayonett style connector. Got to keep up with two charging methods, but at least the type C is nearly universal and everywhere these days.
No heavy use of the grinder, but did put it to work removing more silicon sealant on the camper. Worked like a champ. Almost worked too well, the radial bristle discs that didn't harm the fiberglass gelcoat at cordless drill speeds, can dig in at the speeds this thing turns. Fortunately I suspected that might happen and tested in a hidden area before going to town with it.
Josh those Hyper Tough tools are supposed to be really good. I think you made a good buy there. Torque Test Channel has been hyping them up for a while, pretty impressive specs. Quality over many years might be in question but for the price, who cares, you can afford to replace them!
I agree. I don’t use those tools to make a living, but I use them 100 times more than the average homeowner. The only one I ever wore out, (twice) was the reversible drill with the rattle clutch. And I use that like an impact and a hammer drill, sanding disks/brushes, etc. etc.. I probably didn’t wear it out, I beat it up. But I went back and bought another HyperTough when I did. Can’t beat it for every day stuff.
Ok, not new, but does anybody know what this thing is?
It’s sitting on one of those small 5 x 8 legal pads, so it’s probably about 5 inches long. It has a really big Phillips/reversible/slot screwdriver bit. And obviously the plastic head does something. EDIT/afterthought: when you pulled a bid out, it’s a plastic socket that probably fits something also.
I found it in the shed of miracles when I was cleaning up a little bit. I have no idea when or where I got it, and apparently I’ve had it so long that I completely forgot it even existed. Now I’m curious what it does.
Multi-tool for a particular brand of lawn sprinkler repairs?
A question generator.
I’ve never had lawn sprinklers, but that doesn’t mean I wouldn’t have picked up the tool somewhere or other.
Kind of looks like a golf shoe cleat tool
AJ
Reminds me of some of the electrical cabinet keys I've used.
AJ
I bet that Phillips head and the slotted head are 3/8 of an inch in diameter, way too big for something like that. But it does remind me of that, but those I think are much smaller.
Another thought, oddball variety of the scrench?
What’s a scrench? Is that something from Dr. Sous?
The main gray piece is plastic, a stout plastic, but nothing that could handle loosening a tight bolt or such
And I know for sure what it is now. Done any plumbing lately?
Really? You give us a link to Amazon in another country?
Upcoming TRS Events
Featured Ranger Based Vehicle
